buzzing led problem , thinking of using lower watt bulbs | Page 2 | on ElectriciansForums
Discuss buzzing led problem , thinking of using lower watt bulbs in the UK Electrical Forum area at ElectriciansForums.net
london
i put in a ring of 12 leds in a room (too many in reality)
put in a good dimmer meant to be able take load but lights causing horrible buzz
i am currently using 5w bulbs
if i replace the bulbs for 3w should that reduce the load and stop the buzzing, trying this before having to take lights out of the ceiling and all the work
thanks
if i had 12 leds on a 10 maximum dimmer, if i took the bulbs out of two sockets, would the dimmer think there was 10 bulbs working ? does anyone know of any blanking plates / covers that can go on top of or in the empty downlighter ?
yes 2 way silent trailing edge 250w dimmers led .. varilight v pro .. lights wills dim not to full off and dimming increases the buzzing if that means anything
What happens in the different modes for the varilight v pro? The TLC LED’s only dim 30% in the default mode and they need mode 3 to dim to maximum available whereas Phillips dimmable GU10 dim fully in the default mode which surprised me. It may solve the buzz as well although that may be the bulbs.
Also, we are talking about GU10 not MR16 bulbs?
12 is too many on a V Pro dimmer switch it will fail eventually. I know from experience. The maximum recommended by Varilight is 10 bulbs even though that is less than the 120W rating. I spoke to Varilight and they explained that they recommend only 10 x GU10 LED's max due to inrush when they are first switched on. You need to fit a V Com dimmer switch that can handle up to 20 x GU10 LED's rated at 180W. TLC sell them if you have one near you?
Reply to buzzing led problem , thinking of using lower watt bulbs in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
