Bypass pactrol weather watcher | on ElectriciansForums
Discuss Bypass pactrol weather watcher in the UK Electrical Forum area at ElectriciansForums.net
martin704
Somerset
Hi guys
I have a faulty pactrol weather watcher which controls the night storage heaters this is now obsolete and I can't find a replacement anywhere. My question is can this be removed and bypassed.
I already have a e7 meter that does the switching so can the weather watcher be linked out so the meter activates the contactor for the Off-peak board.
Any help appreciated
Presumably the contactor switching your off-peak board by the Pactrol device is your property, and is not a DNO supplied switch?
I would have thought the safest way would be to install a timer to operate the contactor, making sure the timing is set to tally with the E7 period.
I'm not sure you would be allowed to take a feed from the meter -that's DNO property!
Hi yes the contactor is mine it's not the DNOs. The meter I have already has the switched neutral feed coming out the meter for Off-peak. It then goes into a fuse (only the neutral wire) and a connection box which comes out in 2.5 T+E that splits off into the weather watcher that activates the contactor.
But as the weather watcher is broken the contactor is not being energized.
I did already think of replacing it with a timed switch but as the meter already switches itself over to Off-peak I would have to have a permanent supply to run the timer. but the switching would have to be done on the neutral as I only have a switched neutral (for Off-peak) coming from the meter.
Hello Martin and Avo, I have the exact problem that you have described, i.e. the PACTROL controller no longer functions and a spare is no longer available. To overcome this I have installed an ordinary plugin time switch into a nearby mains socket, removed the PACTROL pcb from its socket and connected the phase and neutral output from the time switch to terminals 6 and 7 on the PACTROL. By adjusting the time switch to achieve the desired heat I find this as an acceptable workaround. N.B. I've installed a 3amp fuse in the plug top and switched off the supply to the PACTROL.
[ElectriciansForums.net] Bypass pactrol weather watcher
hi David
Yea I kinda did the same thing in the end. Just used a timer module to control the three phase contactor. Programmed inline with economy 7 hours.
Reply to Bypass pactrol weather watcher in the UK Electrical Forum area at ElectriciansForums.net
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
