C&G 2382-18 for EICRs | Page 2 | on ElectriciansForums
Discuss C&G 2382-18 for EICRs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Officially there's no requirement to hold any qualification to carry out periodic inspections but you must be competent. But to prove competency the easiest way is to hold one of the following qualifications, others are available:
C&G 2391 level 3 the older qualification
C&G 2391-51 Level 3 Award in Periodic Inspection and Testing of Electrical Installations.
C&G 2391-52 Level 3 Award in Initial and Periodic Inspection and Testing of Electrical Installations.
C&G 2392 Level 2 Fundamental Inspection and Testing qualification.
EAL Level 3 Award in Electrical Installation Inspection, Testing, Certification and Reporting.
Other qualifications are available.
C&G 2382-18 is only an open book exam to show you know how to read and extract information from BS7671 and in no way covers you for periodic inspections.
I think @Strima has already answered this question perfectly.
also, although not a requirement it would be a good idea for him to join one of the competent person schemes such as NICEIC or NAPIT.
this is a great way of proving competence because they check your qualifications, insurance, and through inspecting your work keep an eye on your knowledge.
this is a great way of proving competence because they check your qualifications, insurance, and through inspecting your work keep an eye on your knowledge. subscription renewal date
corrected that for you.
My point was that C&G 2382-18 has a section which covers inspection and testing. See the screenshot I attached in my last post or refer to the C&G 2382-18 handbook:
That only covers on how to find the relevant information within BS7671 such as disconnection times, requirements for RCD protection, earthing conductor sizes and hundreds of other references.
It does not in any way cover how to inspect and test and installation, the courses I mentioned earlier on in the thread do.
Okay, that's what I wanted to know. Thank you
Reply to C&G 2382-18 for EICRs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
"So the question is to register with NICEIC/NAPIT for part P regs will they require other proof of qualification?" Why not contact them and ask...
