C&G Level 2 Diploma Query | on ElectriciansForums
Discuss C&G Level 2 Diploma Query in the UK Electrical Forum area at ElectriciansForums.net
Scotland
How sad am I! Here in Scotland on New Year's eve I'm wading my way through the theory of "Testing Continuity of Protective Conductors" - Method 2 (Long Lead) from the C&G Level 2 Textbook on page 384.
The question is:
"The resistance of a long lead is measured at 0.89 ohms. The low-resistance meter gives a reading of 1.63 ohms. What will the value of R2 be?"
The answer given is given as 0.9 Mega Ohms. Surely this is wrong or am I missing something?
Way off. What do we measure in Mohms?
The question is a lot easier than you think.
Yep, the answer given ( in your book) appears to be wrong.
It appears to suggest that the resistance of the long lead itself has not been removed from the measurement by zeroing the leads.
So answer should probably be 1.63 - 0.89 ohms.
Thank you all very much for your replies...especially on New Year's eve. To give an answer to Strima's question - we measure insulation resistance in Mega Ohms. I figured the answer to the question resistance should be the difference between the reading given for the protective conductor and the resistance of the long leads. Wouldn't you normally just "null" the leads? In any case, I'm disappointed that the book has published the wrong answer (image of the answer attached) Should we let them know?
[ElectriciansForums.net] C&G Level 2 Diploma Query
Let them know that the answer is wrong.
So what is the correct answer?
Reply to C&G Level 2 Diploma Query in the UK Electrical Forum area at ElectriciansForums.net
It was a one time ÂŁ19.99 fee. I'll be reaching out to them though to get that back. It was the only online extensive bank of questions that I...
