L
londonlec
Its perfectly compliant.
I wish someone would come and put a new boiler in for me, for free.
I agree Mr C.
I now see that the installer has spurred from an outlet which has a 13A switched spur controlling it.
Well, personally, i cannot see anything wrong, apart from the fact that if the washing machine trips, it will take the CH with it.
This i cant see as being a hazard, electrically.
The key words we have too look at are "shall" and "minimise".
"Shall" is not "must"...
Which seems pretty unequivocal; number 4 merely demonstrates its use as an interogative not a conditional.1. plan to, intend to, or expect to: I shall go later.
2. will have to, is determined to, or definitely will: You shall do it. He shall do it.
3. (in laws, directives, etc.) must; is or are obliged to: The meetings of the council shall be public.
4. (used interrogatively in questions, often in invitations): Shall we go?
...and "minimise" is not "remove completely"
Not ideal, but not a hazard.
All IMHO.
Got to say that you really are barking up the wrong tree here.
If they had spurred off the switched side of the spur for the W/M that would have been foolish...
but seems as though they have just spurred off the ring circuit.....Really cant see a problem
sometimes you just need to let go of something
Phew. Thank goodness, that's cleared that one up then!
Seriously? That's the best answer? I thought we were logical people, dealing with facts 'n such?
... either way if it is fused correctly nobody will be in danger,,
We have probably all seen lights spurred off a ring if its difficult to get to a lighting circuit,
...is it correct, maybe not, is it dangerous? not if its fused correctly.
Really think you need to make your own mind up
The Regs as we know are not a statutory document and though it can be used in a court of law to confirm guilt or innocence it is still open to interpretation.
I have been asked about 6 times in both a domestic and industrial situation to look at a situation where the loss of a supply and also a shock incident occured if blame could be apportioned to the installer. Everyone of these incidents resulted in a non prosecution as it would have be tremdously difficult to apportion blame.
...But can you say that in regulation 314.2 that the consequences would be dire, inconvinient yes, but not dire.
Could we say that a cooker/ hob that was electrical should not be on an RCD where a socket can trip them, as the very loss of cooking can also be life threatening.
You can have a microwave. oven to get by on, the same as you could have a couple of fan heaters to get by on, before someone can come out and rectify the problem.
As for the other sections of the regulations 314, again how far would you reasonably go to minimise inconvenience,...
it would be far better to have an installation with perhaps 10-12 mini DNO heads...
Yes there is a logical reason to have a boiler on it's own circuit,
...but often many considerations have to be taken into account,
There are no regluations insisting on this and so it is not therefore compulsory to do so.
Thre bottom line to this is if the boiler did trip due to a fault on the ring final,
...could you envisage winning a compensation claim by citing regulations 314 .............I doubt that very much.
