c/u change no Equipotential bonding | Page 2 | on ElectriciansForums
Discuss c/u change no Equipotential bonding in the UK Electrical Forum area at ElectriciansForums.net
J
jimjamjimajam
Hi guys. Am changing a consumer unit but the property has no equi bonding to incoming water. Usually I would make sure it is installed but from where the supply is would be a big job to put it in.
Can I still sign my work off and note that it's been advised or do I insist that the customer pays for the work involved?
Here's the question nobody has asked yet..... Is the water supply pipe plastic?
Yes, but we still have a few who argue that even with the incomming supply in plastic, if the internal pipework is metallic, they still insist on installing protective bonding, even with testing to see first.
My personal preferance is to to any incoming services and install accordingly.
It would need testing in this instance to see if it introduces a potential, what gets me is when the incoming is plastic and the whole install is plastic yet some posts on here say that they would still insist on a small length of copper by the stop tap to bond to? Seems a pointless waste of copper to me
Reply to c/u change no Equipotential bonding in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
