DavidL
I have recently had an EICR on my tenanted 1st floor purpose-built flat, built in 1995. I have received C2 codes for lack of RCD as follows:
5.14 No RCD for additional protection
6.18(a) No RCD for socket-outlets
6.18(b) No RCD for supplies for mobile equipment for use outdoors (this is a 1st floor flat, when would you plug anything in for use outdoors?)
6.18(c) No RCD for cables concealed in walls at less than 50mm deep (electrician has commented that he can't check so has assumed worse case scenario)
6.18(d) No RCD for cables concealed in walls containing metal parts (again the same comment about worse case scenario)
6.18(e) No RCD for circuits supplying luminaries.
Does this really make the installation potentially dangerous, or are these suggested improvement (C3)?
