Very good is this available from NAPIT
Discuss C2 for extension lead on washing machine in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Might as well be. Remember all these code break books regardless who produce them are based on opinions. Its your signature on these certs and so your neck on the block if anything hits the fan. Thats why these books annoy me. Your all out there doing your best, but not one so called governing body will stand by you or any of these books. There for guidance only !! Now we will climb back under our stones.Very good is this available from NAPIT
Be that as it may, the landlord now has an unsatisfactory report, and some legal 28-day clocks have started ticking.The EICR is for the fixed installation wiring, so this is out of scope as well as being a bit silly on his part.
Being devils advocate here. A qualified electrician has seen a potential fire hazard and has gone the extra mile to make the Landlord aware of it from the point of safety.
Extension leads for appliances that have current draw such has washing machines dish washers and tumble driers should never ideally be connected through an extension lead.
So we know its not an ideal solution.
He has chosen to report this on his EICR.
Its not part of the fixed wiring agreed.
But he has sufficient concern over the safety aspect to fail the installation on the basis that a better solution is sought, possibly an additional socket for the machine closer to the one currently used.
And he has done this because he doesn't want to walk away with an its not my problem attitude.
What does the washing machine manufacturer have to say about using there products on XT leads ??
How much will it cost to rectify the problem and have peace of mind for the tenants safety.
Just putting it out there guys.
Agree but what if the manufacturer says an X tension lead should not be used on the appliance. I know I have actually seen this, from them, in the past.If it's a well made extension cable with a good quality plug and socket then there should be no issue. It sounds like it is only of minimal length.
And it can be tested either as part of ISITEE, or at the same time as the fixed installation, to ensure it is safe for use. Preferably with a high current earth-bond test.
He may not do that.He has chosen to report this on his EICR.
Then it is outside the scope of an EICR.Its not part of the fixed wiring agreed.
It's not part of the installation.But he has sufficient concern over the safety aspect to fail the installation
He is absolutely free to comment on it in his report.on the basis that a better solution is sought, possibly an additional socket for the machine closer to the one currently used.
The washing machine is not part of the installation.What does the washing machine manufacturer have to say about using there products on XT leads ??
Again I agree with you. In my opinion your correct. In your opinion your correct. And my certificate like your certificate would be signed by you or me accordingly. However we are not talking about our certificates. We are talking about someone else's. He has signed it, and therefore its his opinion that he is signing against. As long as he is competent and qualified to perform such work. Regardless of if we agree or disagree with his C2 decision it is his decision to make. And the Devils advocate quote I made earlier is for that very reason. This kind of thing will continue to happen, and we all know it. This will not be the last complaint regarding EICRs. Damned if you do damned if you dont.Add a note to the EICR if you want, but it's still not codeable.
Only because the bloody pubs are shut ?Jeez is this still going?
Reply to C2 for extension lead on washing machine in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
