View the thread, titled "Cable calcs for right size cable" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Hey guys as some of you may know that I'm studying electrical installation at York college. I haven't really worked on site yet.
Just wanted abit of help. As I'm doing cable calcs etc which I've got the hang off.
Only issue I have is suggesting improvements as to smaller cable etc. Plus I don't know what the cable size means :( as in if they are too big for a domestic property or whetever we doing the calculations for.
Is there anywhere I can make myself familiar with cable sizes. So I can say this cable is too big etc especially based on ref method etc.
Otherwise I won't know. Just need to understand what the standard sizes should be .
Thanks for any help
You are right but part of the call we have to determine if its correct or not .. so we have to change some of the factors ie group cg etc
So it's important for me to know what a re considered standard sizes or not.
Upvote 0
So are they saying once a size is calculated this maybe considered oversized for installation purposes for example, calculations give you a size of 10.0mm² for a domestic lighting circuit. You then have to change it's installation method to reduce it?
Upvote 0
If you are comfortable with cable calculations then look at how you can change the increased cable size. Reduce the grouping, is there thermal insulation, change the cable type.
Upvote 0
Yes I'm pretty comfortable doing all that. This is why I'm trying to get grasp what are standard sizes or types of cables used. Maybe there's a website. But someone above just posted some .
Upvote 0
Do you have the On Site Guide, following on from your other thread this and Guidance Note 3 would be useful. Tables 4D1A onwards in BS7671 show the cable/conductor sizes.
Upvote 0
Standard sizes are 1, 1.5, 2.5, 4.0, 6.0, 10.0. 16.0, 25.0, 35.0 sq mm upwards!
Is it because your calcs are coming up with figures like 8.6sqmm for example?
Wouldn't anything above 10 be too big for installation purposes? From my understanding 10mm would be okay for a powerful shower. ... perhaps even a cooker. But a cooker is ideally either 4mm or 6mm.
Also could you use a 10mm for like sockets if you wanted to ie ring circuits ? Or would it be too big too install ? I know it isn't cost effective. I know you'd usually use a 2.5mm .. and 1.5 for lighting.
Would 16 plus be too big for installation purposes ie too big to connect etc for the equipment ? Where would you use the larger cables?
Upvote 0
Large cables are used in commercial and industrial fields but how do you define large? 50.0mm² could be considered small up against 300.0mm².
Upvote 0
Depends what you are trying to achieve - on a recent job the DNO installed a 95sqmm cable to a property for a 100A supply but reduced it to 35sq to enter the property, which is much more manageable!
The 95sq was used to minimise volt drop on a long run.
Upvote 0
Reply to the thread, titled "Cable calcs for right size cable" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Electrical Courses
