A
ajdeath
Hi everyone, Ive got to install a sub main for a large bugalow. The supply is in the garage and the 2 nd mains board is approx 40 meters away. I was going to use 16mm t + e, 1 meter in trunking then the rest will be in the loft clipped high up away from the insualtion. ( so no RCD) It will be connected to a 60 amp switch fuse. I could use armoured but the fuse board is plastic making it a expensive jobs. I've done calculations and i think its ok however ive not long been self employed and at my old place my boss did all the calcs so I want tio make sure its ok; any help most gratful thanks Andy
