Cable dammage by drill | Page 2 | on ElectriciansForums
Discuss Cable dammage by drill in the Australia area at ElectriciansForums.net
dpg2
Got a call today by a plumber and while drilling for pipe clips he went though a cable for a ring main what would be the best course of action to repair the cable in the wall.
Cheers all
sparks i agree if possible to replace the leg fine its the way to do it. However if that is nt possibel a crimped sealed connection in wall isnt a bodge either. Th maintenece free joint boxes are fine as well but in some ways simmilar to a crimped connection.
i think there was a thread somewhere before that if a crimp connection was the only way forward then heat shrink sleeving could be installed to give it some "proper protection against moisture ingress"
If the the terminatiion is made using an approriate compression tool (ratchet crimper) then it is a permanent connection abviouly you externeal influences have to be taken into account so putting them into a small box to prevent moisture then sealing in wall is ok
thats what i said in a previous post on here
526.3 iv - conseaded - however how would you explain away 526.5 ii - just curious so I have an answer for my next assessment:)
Is it BS or BSEN standard to appropreate IP code
Yeh! i would,t bury my j/b,s i would have them where i could get to them in the future my friends, i think thats got to be better than burying stuff in the wall hoping it will never breakdown.
What my point is if you cant replace leg and client wont let you channel out wall then crimp connections in a suitable cointainer plastered in wall is acceptable under BS7671 thats all being a bit of a devils advovcate about it but just pushing a point
JBs need to be accesible,not buried.What happens when the next spark comes along or its buried behind a cupboard or tiles.Do you put a notice up,access needed,electrical connection:eek:As scotsparky posted.
All screw connections must be accessible. 526.3 Through crimp connections do not have to be accessible. 526.3
Reply to Cable dammage by drill in the Australia area at ElectriciansForums.net
Sounds more positive.
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
