Markc
Hi All.
Because of recent events I am asking if anyone could also confirm the cable size for the following system?
2 x 4kWp systems, ground mount, side by side. One per phase (only two phases coming to the property and neighbouring farm buildings)
The array is 200mts away from the incomer. (150mts buried direct in ground 50mts clipped direct up outside wall and though loft space)
Also your thoughts on running either a AC cable this length and putting inverters outside or running DC cables this long and inverters inside or may be even half and half?
ALSO
Has anyone any advice on G59 applications? As the system above would fall into the G83-1 notification (I have already checked this out with UKPN) the potential client is interested in a possible larger system in the G59 area. We have not done one of these yet. What are the pit falls, possible costs and requirements. I am awaiting UKPN to get back to me on this also.
Thanks in advance
P.S if anyone wishes to PM me on any of this please do not hesitate.
ALSO
Thanks in advance
