C
claret73
Have a few External PIR Lights to fit and currently the customer has them plugged into a socket in the loft...
Have discussed breaking into the lighting circuit & feeding into Spurs, but am wondering if I need to be using Arctic Flex on the load side to feed outside? Can I use a lesser cable that would be suitable for fitting externally? 1x fitting has a drop of around 4Meters, clipped direct & to the fitting & the others no more than a metre.
Cheers
Cheers
