Cable from inverter to AC isolator
DomB
Silly Q, but just wondering what sort of cable people are using between the inverter and the AC isolator? I'm thinking 16A 3-core rubber flex might look kinda tidy
Cheers
Depends on circumstances but 1.5mm 3core Heat Resistant flex in the main (Its what we carry on the van rather than standard flex) Arctic flex if inverter is outside (Ground mount systems)
I use 2.5mm 3 core flex, it looks smart and makes off into the SMA inverter AC plugs nice and tidy.
