I am due to start a house rewiring job in the new year, due to the customer having the house fully decorated it needs to be done using plastic trunking.
They have had a couple of other quotes that have said that the trunking must be run from the ceiling in a straight line to the socket (which would be a metre or two from the corner of the wall)
I was planning on running the trunking in the corner and then along the top of the skirting to the socket, I cant find anything in the regs or on-site guide to say I can't do this.
Can anyone see any problems with this?
Mark.
Well I would generally, well not insist they put them at the new height, but strongly encourage them to come into line. I do believe its only guidance when considering a rewire though.
That's how I was trying to phrase it, but in reality there's not a chance I would put the sockets back on the skirting, its just a nonsense.
It is only guidance on a rewire mate, now of course we're none of us going to put sockets where flexes can be stressed and there's actually nothing wrong with putting them at 450. I think it looks ok but if the homeowner wants them somewhere else then all we can do is advise.
Agreed, but installing the sockets on top of a skirting board on a surface box ( at a height of no worse than the original installation) I would say has covered this.
Not according to the part p document. The bit you're working on has to be to current part P and BS7671 standards, the rest of the installation can be left no worse than you found it - ie you don't need to upgrade the rest of the installation, but do need to ensure your work complies with current regulations.
"Approved document M recommends that in new dwellings only switches and socket outlets for lighting and other equipment should be between 450 and 1200 mm from finished floor level"
Straight from approved doc P mate.
so it does.
so the bit about having to apply the current regs to your work doesn't apply to this regulation. Confusing.
Part M of the building regs (access and use of a building) states that the building must not be more unsatisfactory in relation to the requirements than before the work was carried out. Regulation 553.1.6 requires that a socket-outlet is at sufficient height above the floor or any working surface to minimise the risk of mechanical damage to the socket-outlet or to a plug and associated flexible cord during use, insertion or withdrawal of the plug.
so it does.
What is part M about?
If none of the requirements of it apply to a situation you are in then why do the wishes of the home owner not trump it?
It says there very clearly "in new dwellings only" there's nothing confusing about it mate.
its all a bit confusing and contradicting and there's no way I am stretching up to my shelf to look at the book at this house, I am only in here because the mother in law is staying with us until Tuesday.
Regulation 553.1.6 requires that a socket-outlet is at sufficient height above the floor or any working surface to minimise the risk of mechanical damage to the socket-outlet or to a plug and the associated flexible cord during use, insertion or withdrawal of the plug.
Thanks Lee
Where is the mention of 450 UKESRail?
Yes really. The problem is people like to pick and choose the regs they follow. This is not only a elec reg but a building reg also. I know it is never followed domestically this is why the domestic sparks out there are not thought of to well in the commercial world. It is as clear as daybthat if you put socket outbof that range you are not installing to the regs. Agreed? If you disagree please quote a reg to me.
There is no electrical regulation setting the height of sockets etc, only a reference to the building regulations which set those heights for new-builds only
I'd remembered the first bit as a general principle, not that the section on access went against that general principle.
Had I thought about it a little more I'd have realised that we've never concerned ourselves with that regulation in retrofit situations, so there would hopefully be a reason for that.
It does make sense now I've thought about it.
You still here, said you were going to bed, lightweight :biggrin:
I went to bed then grabbed the iPad when the mrs was asleep!
we install at 1500 and put boards at ceiling height :)
we do domestic but not new builds but even they are at celing height
I will never put a new board (not a change) at ceiling height, i usually put them at shoulder height to me (makes it easy to put together then!)
Thanks Lee
You know what? I am not afraid to admit I was wrong here. I checked this morning and it is only new build that must follow Part M. That is what this forum is all about. What I would say though is if you were re-wiring an elderly ladies house and the sockets were all just above the skirting I would consider it a breach of the building regs to put them back as they were.
Why? Existing installations are not covered by part M of the building regs. Only new builds or anything that comes under LABC is.
Nothing wrong with moving the height of sockets as long as they are no worse than what they were installed originally.
There are several conflicting building regs with respect to height of DIST boards.
for example.
if in a building that was reasonably likely to flood at the suggested height...well tgen it can go higher...
Why would you put them back at that height? To cause the lady no end of suffering?? Reg 553-01-17 states that where portable equipment is likely to be used the socket should be conveniently accessible.
You say nothing wrong but I would leave that re-wire thinking I had not done what was right for the user.
please dont try and make out I said anything you have just implied in your reply.
I haven't asked for an admission mate, in fact if you care to look I have said that I enjoyed our discussion. No I would not put an elderly person's sockets back at skirting board level, I'd advise them to have them at a height more appropriate to their physical condition whether that be 450, 550 a metre or whatever. I rewired a flat for a young woman in her 20s a few weeks back and her sockets, after a discussion, went at 450. Had she objected to that then no amount of advice would have changed it, they'd have went in at the height she wanted them as long as flexes were not put under strain or risk of damage,
This is why we have a section call Variations......or in the real world....common sense.
New build regs are to cover dda and all aspects which could be considered.
If you rewire a house for a wheelchair bound person, you may consider lowering the light switches to suit him, not the regs. Moving the sockets to 2m, to suit him.....its his house, he owns it, and he decides what he requires......if you fill out your variations from the bs, you are explaining your practical reasons for these variations.
Wales
Cable in Plastic trunking
markadams,
tazz,
