F
fixit4u
Hi every-one,
called to an house late last night who had just had the gas board there for a gas leak and the call-out guy,s had drilled through a wall and hit the ring-main supply and knocked out all the power,the cable was proper damaged and in a cup-board wall, i am asking if there is a pref for joining twin & earth together as i only had connector blocks with me 30-amp and joined up with this to re-store the power for the customer, the son who was there was a joiner and was going to box the area in, in the morning, the point is,is this fine as it is as can,t find anything saying connector blocks can,t be used or should i have used crimps etc instead which prob be neater job ?? :dizzy2:
