Cable reference methods | on ElectriciansForums
Discuss Cable reference methods in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
rob the sparky
Hi,
im new to this site so please forgive me if this question has been asked,im looking to find out what the codes were for the type of wiring column on a test sheet.i know that there are ones on the test sheets but just wondered if there were anymore available
Yea you are correct,partialy.however,the codes on the bottom of the test sheets are for the type of wiring,for which the appropriate one would be picked,and entered into the sheet.
The other code required for the test sheet,is the reference method.This code,which used to be a number,prior to the 17th edition regs,is now a letter,which can be obtained by reference to the latest wiring regs,and entered into the test sheet.
Reply to Cable reference methods in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
