Hi
Would this be allowed : Fitting a double socket to a chimney breast , chased a horizontal run across the chimney breast then to the first corner then along horizontal to about 500mm to meet up with a double socket feed that comes down to a double socket and then it follows that run down into that back box to pick up the feed .
The cable is in a oval plastic conduit and will be just below the surface , the house has RCD protection .
Spike
Spike
