Cable run for Fixing a double socket on Chimney Breast | Page 3 | on ElectriciansForums
Discuss Cable run for Fixing a double socket on Chimney Breast in the UK Electrical Forum area at ElectriciansForums.net
North yorkshire
Hi
Would this be allowed : Fitting a double socket to a chimney breast , chased a horizontal run across the chimney breast then to the first corner then along horizontal to about 500mm to meet up with a double socket feed that comes down to a double socket and then it follows that run down into that back box to pick up the feed .
The cable is in a oval plastic conduit and will be just below the surface , the house has RCD protection .
Spike
Getting your opposite and adjacent mixed up there? Trigonometry not you strong point?
Well I am a little older than you I guess , not really worked in the trade for roughly 20 years or so , so a little relapse now and again in spelling etc is inevitable :).
Actually I was quite good at Trig n Tech drawing in my younger days
Just imagine the confusion if he'd mentioned the hypotenuse as well!
hypotenuse........
[ElectriciansForums.net] Cable run for Fixing a double socket on Chimney Breast
Reply to Cable run for Fixing a double socket on Chimney Breast in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
