Cable Size And Amperage It Can Carry | on ElectriciansForums
Discuss Cable Size And Amperage It Can Carry in the UK Electrical Forum area at ElectriciansForums.net
L
Lordy9099
Hello,
I just bought a LED security light drawing 3.6W and used a 0.75mm cable to run in inside then into a fused switch spur, and a cable from a 1G plug socket next to it to create a spur, will the 0.75mm cable be OK to carry the current? And what fuse will be safe for the fused switch spur?
Callum Lord
come off your socket outlet in 2.5mm to adjacent FCU, then fit a 3A fuse, the 0.75mm will be fine. as the 0.75mm is quite small, fit ferrules to the terminations in the FCU.
Hello,
Right but OK, I have fitted it today and ran 0.75mm from the ajacent socket at the moment, what shall I do at the moment untill I can grab some 2.5mm cable tomorrow? Will it be OK for the moment?
Reply to Cable Size And Amperage It Can Carry in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
