Cable Size And Amperage It Can Carry | Page 2 | on ElectriciansForums
Discuss Cable Size And Amperage It Can Carry in the UK Electrical Forum area at ElectriciansForums.net
L
Lordy9099
Hello,
I just bought a LED security light drawing 3.6W and used a 0.75mm cable to run in inside then into a fused switch spur, and a cable from a 1G plug socket next to it to create a spur, will the 0.75mm cable be OK to carry the current? And what fuse will be safe for the fused switch spur?
Callum Lord
was told on my last nic inspection that the smallest cable you can connect to a fused spur off a ring main is 1.5mm inspector picked me up on it as i had fed 150 w towel rail element through switched spur with 3 amp fuse fitted
That is correct if considering T&E from the ring to the FCU on power circuits.
Table 52.3
Reply to Cable Size And Amperage It Can Carry in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
