cable size and max load | on ElectriciansForums
Discuss cable size and max load in the UK Electrical Forum area at ElectriciansForums.net
J
jimmy84
What is the max load a 6mm cable can take think the run is about 16 m clipped surface s w a cable 5 core
Reply to cable size and max load in the UK Electrical Forum area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
