cable size for 2 x 6kw fryer's? | on ElectriciansForums
Discuss cable size for 2 x 6kw fryer's? in the Australia area at ElectriciansForums.net
A
a1pacino
Hi all, can anyone tell me what cable size I should use for 2 x 6kw fryer's which has a run of 20 meters, it's been a while since I had to work these out and have got a little rusty so I used an online cable size calculator which gives me 4mm- is this correct? Any help would greatly appreciated!
it is clipped direct SWA and it is 2 separate 6kw supplies both with isolator's and both with 32 a C breakers. It is a twin fryer for small kitchen in commercial building
Reply to cable size for 2 x 6kw fryer's? in the Australia area at ElectriciansForums.net
To be honest James I use an app- Electrical Calculations. It auto calculates the cable size once you enter the specifics/parameters. Voltage...
Thanks for the advice! Much appreciated
