Cable size for main entry to house. | Page 2 | on ElectriciansForums
Discuss Cable size for main entry to house. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not tough enough to stop a sharp stone or other debris getting through it, in a direct burial installation, nor a shovel or garden fork come to that!! lol!!
So you've not had a play with the new stuff the DNO's are installing. For BS7671 it isn't compliant but believe me it’s as tough as old boots.
No, haven't touched the stuff for quite a while now Tony!! lol!! Not a real lover of the cable myself, it can be a real pain getting respectful end terminations, that don't look as if it's been installed by a 1st year apprentice!! The DNO don't have that problem, they just split it in the service head willy nilly, no-one ever see's the state of it!! lol!!
only when you pull the fuse, which, of course, you never do. LOL.
Not even then, in most of the service cut-outs i've seen!! Generally terminated (if you can call it that) in the square case below the fuse carrier!! lol!!
Reply to Cable size for main entry to house. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
