Cable size for these | Page 2 | on ElectriciansForums
Discuss Cable size for these in the UK Electrical Forum area at ElectriciansForums.net
B
brizospark
Got an induction hob (7.2kw) and an oven (3.68kw) to install in a kitchen
You guys think 1 x 10mm T&E would be ok?
Run is approx 10M under floor
Just a waste of time and money.
6mm every time here, why do we waste so much time worrying about simple things like cooker installations.
Amazes me every time i see one of these cooker installation threads!!! Same goes for wanting to change perfectly adequate 16mm tails for 25mm tails on a 60/80A cut-out fuse, and then struggling to get the 25mm tails dressed into the CU!! ...lol!!
Reply to Cable size for these in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
