W
waleed
Hello,
I have a farm where electricity source is about 240 meters from the well , at which I already have installed a 30hp Grundfos submersible pump. I have laid a 50 mm cable from the source to the control panels on the well (240 meters 50 mm cable buried ) , and then I used 35mm flexible cable from the control panel to the submersible pump about 210 meters deeps.
It has been installed since a year wit no problems , and I wanted to use an irrigation pump (10 hp) near the area of the well , question is Can power this pump from the same 50 mm cable used for the submersible pump ? i.e. about 55 amps for the submersible pump and 15 amps for the irrigation pump ?
