synergy power
Hi everyone,
I've just had my electrician run the AC Cable from the inverter to the consumer unit but i think he has used the wrong cable size.
Background Information- Its a 4 kW (Sharp NDR-250A5) system split over two strings running to a SMA SB 3800 inverter on a farm outbuilding. From here the electrician has used 2.5mm SY cable suspended overhead to the farm house about 20 Metres away. I would say the total AC length is around 30-35 Metres, my main concern is the 2.5mm SY cable not being adequate enough for the distance.
Off my head i would have thought 6mm would be enough? Could i have your opinions please
