cable span | on ElectriciansForums
Discuss cable span in the UK Electrical Forum area at ElectriciansForums.net
hello would like a little advice re cable span. have a customer who has had a new shed built 1.5 ft away from detached garage. Garage has own supply circuit (2.5mm SWA via 16amp mcb main house C.U. RCD protected) intending to feed new shed from garage via SWA supported with conduit. My question is reguarding the span. i intend to span at 1.5 ft from the ground between garage and shed, but unsure as to weather this would breach regulations. To add there is obviously no access between the garage and shed.
any advice much appreciated
18" span, 18" up. call that a cable span?
this is a cable span:
[ElectriciansForums.net] cable span
Reply to cable span in the UK Electrical Forum area at ElectriciansForums.net
Without specific information I could only a give belt and braces ‘cover all bases answer which will definitely be costing you considerably more...
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
The original post could be clearer, but I believe you're essentially asking if the use of a lower rated rcbo would prevent tripping of an upstream...
nicebutdim
N
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
