Cable thickness | Page 2 | on ElectriciansForums
Discuss Cable thickness in the Australia area at ElectriciansForums.net
J
jamminuk
I've come accross a few jobs where 2D light fittings control gear has gone (after only a month of being installed) and i noticed that the cable feeding them were larger then 1.5. On one it was wired in with really think flex that you'd normally use to wire in a 3KW storage heater. Just wondered if using thicker cable like this actually damages the control gear, being less resistence and there for more Amps. Apart from it being un-neccesarily large for the current needed.
Cheers
Ben
I must admit it would hurt more getting hit round the head with 10mtrs of 16mm T&E than it would if it was 10mtrs of 2.5mm T&E but that's nowt to do with ohms / volts / current or rasins in fact!!!!!!
After reading this thread, I agree with whoever said it's a dodgy batch of fittings.
otherwise if you were increasing the conductor size due to thermal effect, volt drop etc.
I have worked on a few projects years ago where the lighting was wired in 2.5 and general power (32amp ring mains) was wired in 4mm.
Reply to Cable thickness in the Australia area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
