A
anthony1609
I had a sparky round to price up a job, the job was to put power to the summer house in the garden, the price he was going to charge I thought was over the top, was looking at doing it myself, could someone tell me if the following would be ok
i would be planning on running a spur from the house to the summer house, inside the house it would be a 13amp switched fuse
i would feed this cable outside to an outside junction box, where I would then use 2.5mm black rubber cable, the cable would be over 6 foot from the ground, I would connect this use m20 glands to the junction box, then run the cable to the summer house, the run is about 15 metres ????
on getting to the summer house I would then put another junction box on the outside, feed the cable into the summerhouse from inside the junction box, at this stage I would swap to 2.5 twin and earth
from this junction box I would Connect the cable to a rcd switched fuse, from there I would run the cable inside the summer house using round condit, this would feed 2 double sockets and 1 heater
does this sound ok or am I way of the mark
ps sorry for going on
