Cable/wire strippers?? | on ElectriciansForums
Discuss Cable/wire strippers?? in the Electrical Tools and Products area at ElectriciansForums.net
Yorkshire
Hi guys
Can anyone recommened a decent cable stripper for flat and 3 core cables?
Here's a couple ove seen online.
And also....
Has anyone had any experience with either of this or any other ?
Thank you.
I have the CK and use them heavily. They work well. They can just about do 6mm but I tend to use a cable knife for 6 and up.
I replace them when they eventually lose their bite which seems to be 1-2 years.
I have a cheap old pair of kewtech ones which are identical to the CK ones
as above they will strip single cable up to 6mm and strip the outer sheath on 1.5 and 2.5 and 4mm no problem and 1mm and 1.5mm flex no problem.
Reply to Cable/wire strippers?? in the Electrical Tools and Products area at ElectriciansForums.net
