Cables and high powered appliances | on ElectriciansForums
Discuss Cables and high powered appliances in the Electrical Course Trainees Only area at ElectriciansForums.net
DeanoRN
Trainee
Birmingham
Hi all,
Just a quick question,
In a ring curcuit in a kitchen with high powered appliances for example, would the cable get warmer where the appliances were plugged in? Like if they was all plugged in a
Certain area would thst area be warmer than the rest of the run or would the current draw warm up the whole cable equally?
Cheers
Deano
cable should warm up evenly. if there are hotspots close to outlets, that would suggest a poor connection.
Hi all,
Cheers
Deano
If the heat is localised it's more than likely a bad connection
It would also depend on how the RFC is wired, they should be wired im such a way that the current is balanaced down each leg to each point of use. Alot of people will pull a cable to the nearest point and then futhest point then just link them along the way which can cause it too happen also.
Reply to Cables and high powered appliances in the Electrical Course Trainees Only area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
