Grantr37,
I know exactly what type of cable you are referring to above, and it is as you say ''Industrial'' standard, and as such, utilised where additional cable sheath protection is required. Don't get confused here by saying that standard SWA cables can't or shouldn't be direct buried, They Can and Are every day, in every country throughout the world.
I have been involved with literary hundreds of thousands of metres of both direct buried and buried ducted cable installations. from MV to LV, ...from the smallest to 600 sq mm multi core SWA cable, and in all types of soil types. To the best of my knowledge, all those cables were standard grade XLPE/SWA/PVC....
If a cable trench is constructed correctly and the cable(s) pulled in and laid correctly you will rarely if ever have any problems with those cables over a good number of years. Now i am talking about major project installations here, where the contractor, or the designated electrical contractor will have all the necessary equipment in order to correctly install such cable installations such as calibrated electromechanical cable pulling devices, numerous cable pulling wheels/dolly's, and the supervisors and man power to get the job done in a satisfactory manner. A Sole Trader on the other-hand will in most cases not have any such equipment, but can still conduct a good installation if he takes his time and takes care in such a cable installation. His main problem is taking care not to damage the cable sheath, and to immediately repair any such damage prior to back filling.
Oh, and cable ducts are no protection from water ingress either, i've known of several ducted cable systems, along with the underground access rooms, being totally flooded for 3 months of the year, ...every year!!! One such room, had both MV and LV T joints located in there!!! Correct..NO, but for the 5 years or so that i was aware of this situation, there were no problems with any of the installed systems in that ducted installation either!!!
