Cables not long enough in CU change... | Page 2 | on ElectriciansForums
Discuss Cables not long enough in CU change... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Crimp and sleeve, cheap, neat and less work. This will benefit the customer.
Reply to Cables not long enough in CU change... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
They do a cy type with pur coating and it is even tougher but is shielded
