Cables through drilled joists | on ElectriciansForums
Discuss Cables through drilled joists in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Hello peeps, just looking for clarification on my practices here .
In the past , I have taken many cables through the same hole drilled in a joist . Mostly lighting and smoke detector cables , not heavily loaded ones , but on site , time is sometimes critical.
Have I followed " normal practice " here , or have I committed a serious bad practice?
Thanks in advance for honest replies .
Draw new one in very slowly if it's getting a bit close. You can build up heat and melt insulation off the fixed cable quite easily.
and a squirt of washing up liquid helps prevent damage. also you will have the benefit of clean cables.
[ElectriciansForums.net] Cables through drilled joists
https://www.screwfix.com/p/ideal-yellow-77-wire-cable-pulling-lubricant-950ml/44462
Reply to Cables through drilled joists in the UK Electrical Forum area at ElectriciansForums.net
