calculate over current protection csa | on ElectriciansForums
Discuss calculate over current protection csa in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
hi all have a 32A 3036 circuit which feeds a 45A DP isolator from there 3 radiale circuit wired in 1.5mm with fuse spur providing upstream over current protection
now can any one remind me how to calculate short circuit current to be sure cable will be protected due to a short feed side of the fuse spur
cheers in advance
Hi Lenny
yes I am thinking adiabatic I know each circuit is protected against over current up stream but as the OCP is a 3036 I want to check cable will take a short and safely clears the 32A3036
Archy there is no chance of riping it out but if need be some alterations at the supply end
are you looking at the 3036 (32A you sure?) covering the the supply cable (6mm ?) or the 1362 in the spurs covering the 1.5/1.0mm.
assuming T&E thermal constraints.
Reply to calculate over current protection csa in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
