Calculate power consumption | on ElectriciansForums
Discuss Calculate power consumption in the Australia area at ElectriciansForums.net
A
ashokkumar8226
Hi,
i have projector voltage is 110-240v and max power 300w what will be the consumption of power in one hour and what is the load it requires.
Thanks & regards
Hey Dan.
the 1.3 A is the current used by the 300W load in the original example - 300W/230V - 1.3A, power triangle.
Then divide 1 kwh by the 300W load to get a sum of 3.33p per hour roghly rounded up to 3.5p.
Hope this helps.
Ne bother.
It is amazing though how much we were taught and how much we actually use in day to day life. Forgetting it is a dam sight easier than learning it ever was and trying to remember it again is even worse.
Cheers.
Reply to Calculate power consumption in the Australia area at ElectriciansForums.net
can you post a picture of the heating element? if possible with the power off and the cover off.
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
