Calculating gauge of wire | on ElectriciansForums
Discuss Calculating gauge of wire in the Auto Electrician Forum area at ElectriciansForums.net
Cardiff
Ok.
I've fitted 2 tone car horns in place of 1 tone horn on my Renault Kadjar. The factory horn is weak.
I'm attaching a photo of a waterproof scotchlok crimper connector which will connect 2 factory wires to new wires to horn. The car horn runs via 10 amp fuse.
My question is: does anybody know the gauge size of horn wiring I bought from halfords? I can't for the life of me tell which of these connectors will be correct size.
The reason for this type of connector is it seals the ends so no moisture can get to bare wire as connector will be behind grille.
Any alternative as its the only connection I can make as its limited space.
This one is particular good as it's an inline terminal connection.
Read more: Quick splice; Scotchlok? - https://www.diynot.com/diy/threads/quick-splice-scotchlok.545919/#ixzz6NjMzDL00
  • [ElectriciansForums.net] Calculating gauge of wire
Reply to Calculating gauge of wire in the Auto Electrician Forum area at ElectriciansForums.net
To be honest James I use an app- Electrical Calculations. It auto calculates the cable size once you enter the specifics/parameters. Voltage...
