calculating main earth size | Page 2 | on ElectriciansForums
Discuss calculating main earth size in the UK Electrical Forum area at ElectriciansForums.net
J
jamesBoater
i am just a little unsure if i need to use 5 seconds as my D/T or 0.4? PFC obtained through Ze test at origin.
i have been told 2 different answers and any guidance would be helpful.
thanks james
You could just refer to table 54.7 of the regs book, where the sizing of the earth has been calculated for you I believe?
the adiabatic is good for calculating CPC/earth size for singles.....and also to make sure that any CPC within a cable is good for the time/current curves for the particular choice & setting of OPD being utilised...
say you had a ring final where the live conductors were intact but the CPC was broken....however all points served had R2....this is when the adiabatic would come in handy....it would confirm the difference between a pass and a fail.....
Reply to calculating main earth size in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
