Calibration for MF tester- How much!!! | Page 2 | on ElectriciansForums
Discuss Calibration for MF tester- How much!!! in the UK Electrical Forum area at ElectriciansForums.net
portsmouth
I am Interested to know what you are paying to have your MF tester calibrated, and by whom and how often do you get it done? More info later
Megger calibration certificates and UKAS calibration certificates do not give an expire date
Megger calibration certificates have a box next to Date Commissioned which you fill in when you start using the meter .
Their is no expire date on UKAS certificates as the Lab does not know how many times the meter has been used , the conditions,etc.
Most non UKAS labs certificates give a recall date of one year after calibration.
a one year calibration interval is only a recommendation however most schemes want it
yeah I realise now it was date of commisioning dec 2012 thanks for reply
now..
it would all depend on how many instruments you are using...
so, for instance i use 3 MFTs...plus seperates ...as i sees fit..
i have a checkbox...this i can use to verify month by month any measuring instruments...so if there are any anomalies the instrument can be taken out of service until either repair or replacement ...and the NIC like to see that you are keeping month by month records of instrument accuracy..
the way i do it generally is get the MFTs put through the callibration house...these can then be used to prove the checkbox is applying correct resistances etc at the test plugs...
the other kit can then be put on the checkbox to verify continuing accuracy levels within the instruments tolerances...
so, just because you have reams & reams of test gear (like me...lol) dont necessarily mean a hefty cal bill every year...
sometimes a decent, comprehensive checkbox just makes more sense...
+1 foir Glenn's monthly cross check of everything against an instrument freshly stickered at the cal service. It's a matter of common sense which units are the most likely suspects. An instrument sat on a shelf in a warm dry office and used once a week is less likely to go out of calibration or develop a fault than one rattling around in the back of a van, used 8 hours a day, sometimes in the rain etc. The idea of using something for a year without checking against anything else is daft, imagine the workload if you discovered that every test you had done in the last 12 months was invalid! So, if you have two units, and you get them done alternately but cross-check regularly you halve the overall cost of calibration but get a better level of security in your readings.
quite rite Lucien...
i mean...why wouldn`t you keep an ongoing check on instruments?...after all, the values obtained by it/them are the ones going on the certs...
Thanks to all for comments and all the useful information. Last year I was forced to join a scheme, and I chose Elecsa. My Kewtech KT64 hadn't been calibrated since I purchased it (2007). I did however check it, and also my digital MM against my Kewtech FC1000 checkbox. As the results were always within a few percent I never saw the need for calibration.
However, the Elecsa assessor saw it differently. Although accepted by Elecsa I was given a non compliance with 30 days to correct. He was prepared to accept a 3 year calibration of the checkbox, which with hindsight I guessis is entirely reasonable, and I would have to keep monthly records. In fact I test my instruments before each job, so better than the monthly check. I also keep the checkbox and the test instruments at home whilst not testing to protect them from the harsh environment of of the van and site.
Personally I feel that if you have 3 instruments that give agreeable readings that a 5 year gap seems more reasonable, because calibration adds yet another cost to our work.
Like Graham I chose to get my checkbox calibrated at PJO Industrial and I can't praise their service enough. I chose a week where I was on the same site for a whole week. On the Monday the checkbox was collected by their courier and returned on the Wednesday calibrated and certified. What I particularly liked was that I didn't have to go home and see one of those infernal post office red cards and waste time going to the parcel collection office to pick up the item. The complete service cost ÂŁ41 including VAT. This also included a repair to a 12V DMM socket(which I never used) that had ceased to function, and at no extra cost.
PJO advertise their service on ebay Electrical Calibration Service Megger, Fluke Etc Fast Collection & Delivery | eBay and I see the cost is now ÂŁ46 inc VAT. Anyway thanks to all for the input...and a great forum which although not a contributor (till now) I have read for many years. As a sole trader you can become a bit insulated from information so it's always great to read every bodies experiences which really adds to my knowledge base. Happy New Year to all!!! Pete
Reply to Calibration for MF tester- How much!!! in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
So, I’m more aiming for the domestic setting myself and I don’t plan on EICR straight away. I am almost certainly not aiming for the industrial...
