Calibration | on ElectriciansForums
Discuss Calibration in the Electrical Tools and Products area at ElectriciansForums.net
Daley
Where do you lot send your meters to get calibrated? And roughly what do you pay?
Daley
Usually use a local (ish) calibration service, I drop off and pick up @£60 but thinking of using the local wholesaler calibration day as it is closer and still £60.
In both cases I think the conservatives will state the acclimatisation time has not been done, but I do not care, it will be correct within an ames ace, precision is not my strong point!
Wholesaler calibration days round here used to run at about £25, I worry about the accuracy of their equipment though considering the circumstances.
I was surprised by the wholesaler price, after all the calibrators are saving money by doing loads in one go so should pass the saving on.
Still it is only a small (but good) wholesaler (it was still £50 at the larger ones ten miles away)
Exactly!!
Fine if all you want is a sticker on your MFT or whatever!! The certificate itself isn't worth the paper it's written on....
Why pay 60/70 quid to get a duff calibration on your test kit, when you can pay the same to have your test equipment tested correctly by a certified lab!!
Hi Phil
Where about's in Wigan mate, I usually use Testermans about £50, they collect and return, you just have to box it up safely lol. On last years cert he gave me a marginal pass on 300mA rcd setting the tester is now 4 -5 yrs old, so may get a second opinion from someone else on its condition regarding the marginal pass. I think it could have been caused by the batteries being low they dont change them. The first time I sent it to them for calibration with New batteries installed Duracell ultra, the year after I had been using it and the batteries were about 10v which is when I usually change them but I am not sure if this affected the result as I know nowt about calibration of test equipment.
Megger did it first time and they provide you with new leads, batteries etc but are expensive at about £100 mine was still under warranty so was free, and I had a issue regarding the socket tubes or leads this was when it was new and hadnt been used and was affecting my continuity readings couldnt get a stable reading.
Can't rember, ask Chris, I'd have to dig the last invoice out.
Mine was about £700 to buy so I'm funny who I'll just post it too so I don't worry too much about cost
think I paid somewhere around £40-50 also get a discount voucher for the year after
Only gripe I have is I think they may have lost my long probe adapter for the Megger Test Probe and theyre about £20 for a new one But I cant be certain it was them so didnt bother complaining
Testermans is £55 think that is for collection and delivery but check website or contact, but they also advertise on the E bay for £41 and also there is a voucher available which when applied reduces it to £31
I use Cuthbertson Laird. Think it's about £70 plus VAT for my multifunction tester and maybe £80 plus VAT for my PAT tester.
Reply to Calibration in the Electrical Tools and Products area at ElectriciansForums.net
    • Friendly
Where to calibrate (MFT) in London UK
This is an RSS feed of thread: Replace testo 327-1 or have it calibrated? Content of the thread: Hello, I've got a testo 327-1 that I purchased...
