N
nickblake
intresting one this Call out ,customer lost power got there the only house in darkness , DB cover off dead as a doo doo not sign of life at the meterso switched off every thing put screw driver down supply back on , mmm me thinks power cut , switched power on instantly power went off again ,mmm even odder me thinks ,switched off again power comes back on , Voltage check 215 volts ,Ze 108 ohms just a little high for a TNCS i thought Yes befor you ask it was joking i know it should be less than 0.35 ,then elder chap from next door next door pops round have you lost your power mines just gone off , oh dear big problem here , then the street light goes off and flickers back on 2 elderly couples with no power , no gas , so first job call DNO , arrived in half an hour couldnt do anything till following day . so me being me popped home 2 flasks of boiling water and a couple of led lights ,and left them to it , popped in this morning with another couple of flasks of hot water , then called in again this evening to find half the road dug up cable melted in three places but the main fault was under a guys concrete drive , so DNO carried out some temp repairs to get the customers power back on all happy
