Can 2.5mm flex ever be wired to a socket? | Page 2 | on ElectriciansForums
Discuss Can 2.5mm flex ever be wired to a socket? in the Australia area at ElectriciansForums.net
Discharged
As per the title, really. When I say socket, I don't mean on a ring, I mean on the end of a flying lead.
This is all becoming much clearer to me so, so many thanks for the info. One thermostatic controller I know of has a 10A relay and the other a 16A relay... it now strikes me that the only reason the 40A relay is being used in the former is to boost its utility. In the latter, the 16A, it surely is not needed for a 3kw fire?
The way I come to this conclusion is by 3000w/240v= 12.5A - well within the 16A's capacity. Is this correct reasoning/maths?
What concerns me is that there is a controller out there with a 40A relay added, using 2.5mm cable, but with a 13A plug. How can that make sense? Should the advice be to not exceed 13A - not least because of the size of the plug's fuse?
no............................... how much do you think a component company will charge if they have to make bespoke components? Your 16 amp only relay will cost 10's of pound instead of a generic 40amp one that will do anything upto 40 amps and cost a tenner.
They will make 2 or 3 relays of differing sizes and use them accordingly. They most like make the 10amp for smaller loads as the resources will be smaller and it is more cost effective. anything over 10 amps upto 40amp another type.
Malcolm, I think you've really hit the nail on the head. I don't think the one I bought was DIY - it's far more likely that it was designed to be hard-wired in somewhere; why otherwise put that big relay in? I understand what you're saying about the component manufacturer, however.
Many thanks, this has been a real help.
Reply to Can 2.5mm flex ever be wired to a socket? in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
