Can a dimmer switch be used to control drill speed? | on ElectriciansForums
Discuss Can a dimmer switch be used to control drill speed? in the DIY Electrical Advice area at ElectriciansForums.net
Peterborough
Hello
As the title says... ;)
I'm thinking about having a 1.8A 400V bushed fixed speed drill, mounted in a press, connected to a dimmer switch to control the drill speed.
Any ideas, or advice?
And please, to those who think I'm silly to think such an idea etc, I can do without the criticism :)
This is only an idea at this stage...
I'm not sure if the mechanism the dimmer switch uses to dim would translate very well for the drill, and I'd be sure to pick a dimmer than could handle the 400V but like @telectrix says, best way to find out is try it out! Be careful and don't get hurt with your experiments!
A dimmer switch isn't suited to a fan, which is a motor, so wouldn't imagine it would be for a drill motor.
Get a variac 1af from "watt bits" and build your own that way would be my suggestion.
Is the motor DC or AC or universal? This can make a difference , a dimmer switch may not work well on an inductive load, though there are dimmers available which claim to work well on either resistive or inductive loads. There are relatively inexpensive speed controllers on the market that would be more suitable for your drill.
Reply to Can a dimmer switch be used to control drill speed? in the DIY Electrical Advice area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Thank you for the suggestion!
