J
jjrules2
Hi,
Unfortunately during the installation my client moved the position he wanted a PIR light, meaning even with excess cable and due to the progress of the house, I had to joint box a cable to extend to the new location.
So, the wiring goes like this.
CCU to switch - twin and earth
Switch to Junction box - three core and earth
Junction Box to PIR light one (one that moved) - three core and earth
Junction box to PIR lights two and three - Three core and earth
So basically I did take a 3c and earth from the switch to light one, back out to light two, ending at light three. But due to the moving location I had to install the joint box. Now I have installed the PIR lights and they remain permantly on when wired like this -
Switch -
Live from twin and earth goes in common with permanant (black) to lights
Neutral goes in connector block at back of switch box with grey to lights
Same with earth
Brown switched live from lights goes on it's own in L1.
Switch does nothing when turning on and off unless you remove the permanant live, then the switch works fine. But I have wired these up at work like this and the PIR works when dark and movement is detected, or if you turn the switch on!
Any help would be appreciated, i'm sure i'll get the sarcastic immature comments from the old boys as well :wink_smile:
Switch -
Same with earth
