Discuss Can a Non POE device be powered using a CAT6 cable using POE splitters and Injectors? in the UK Electrical Forum area at ElectriciansForums.net
Its a camera and it says it needs (100-240V), do I jsut need a PoE splitter ? Or would I need more ?Possibly. It would depend on what the non-PoE device needs in terms of power (current and voltage) and if your PoE splitter matches that!
You mean if it comes with an adaptor or something in the box?That voltage (100-240V) is for AC mains use. Has it got a separate power supply unit?
Typically PoE splitters will output 12V or 24V DC for electronics, they would only work if the camera has a DC input in that range.
Reply to Can a Non POE device be powered using a CAT6 cable using POE splitters and Injectors? in the UK Electrical Forum area at ElectriciansForums.net
