Can a Non POE device be powered using a CAT6 cable using POE splitters and Injectors? | on ElectriciansForums
Discuss Can a Non POE device be powered using a CAT6 cable using POE splitters and Injectors? in the UK Electrical Forum area at ElectriciansForums.net
That voltage (100-240V) is for AC mains use. Has it got a separate power supply unit?
Typically PoE splitters will output 12V or 24V DC for electronics, they would only work if the camera has a DC input in that range.
Reply to Can a Non POE device be powered using a CAT6 cable using POE splitters and Injectors? in the UK Electrical Forum area at ElectriciansForums.net
Nail as a fuse works until it doesn't. When you say certain areas what does that mean? If you have been doing it like this for 4 years why the...
Try to use a catenary wire for better support for your outdoor cable. I'd recommend TP-Link ceiling-mounted access points, which are good options...
    • Winner
