Can an upstream fault cause an RCBO to trip? | Page 3 | on ElectriciansForums
Discuss Can an upstream fault cause an RCBO to trip? in the Australia area at ElectriciansForums.net
L
LlandrilloSpark
Fellas
Scenario - 1 main three phase board feeding 3 further three phase boards with each of those feeding 15 single phase boards containing only two final circuits each.
The fault is on the final circuits, ive tested the final circuits and all clear, can a fault on the distribution circuits upstream cause the RCBO to operate?
cheers
Reply to Can an upstream fault cause an RCBO to trip? in the Australia area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
