Can any DIY Dave change a light pendant fitting? Like for like. | on ElectriciansForums
Discuss Can any DIY Dave change a light pendant fitting? Like for like. in the UK Electrical Forum area at ElectriciansForums.net
A
animox
Hi
Just a quick one.
Cheers
I would day common sense applies. If you feel competent to do it I don't see why not. To try and stop this is a slippery slope which ends up with people not being allowed to maintain there own cars, etc. Any doubt though and I would get an electrician in, especially if you think all the same colour wires should be connected together :) Tin hat on. Second tin hat on standby. :) Daz
Reply to Can any DIY Dave change a light pendant fitting? Like for like. in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
