Can anyone guess an work this out | Page 2 | on ElectriciansForums
Discuss Can anyone guess an work this out in the UK Electrical Forum area at ElectriciansForums.net
A
axel132132
[ElectriciansForums.net] Can anyone guess an work this out
[ElectriciansForums.net] Can anyone guess an work this outAn
anyone tell me what type of cable this is? Its hv cable underground for electric board but never seen it before and engineers have no idea its rated at 11kv - the outer stranding bells through to the inner core but what are the papers between about
engineers are confused say its not a screen or a strenghtening
ideas anyone? Its old around 1910 tape armoured lead covered cable
What is the network voltage ? A lot of the old DC networks were converted to 6.6KV that could account for the concentric construction ie + and - in each core. They may have been bonded together to increase current carrying capacity.
that's what i was thinking in post #11. the doubling up to increase the CCC.
Yes I'm sure you're right Tony, I just saw thick strands to begin with but realised that's not likely. I can't see how it would have been made for DC and then re-purposed for AC, unless it was 3-phase DC
and then it would only have been for LV, as HVDC was the province of special systems like the Oxford 2kV system.
I'm also keen to know the present working voltage.
Looks similar to the 95mm2 triplex I'm used to seeing. But a copper core rather than aluminium core. (More than likely due to costs) [ElectriciansForums.net] Can anyone guess an work this outwhich we use on our 11kV systems.
I am still a sparky in training, but the copper "sheath" on the outside is connected to earth, and isn't used as a power carrier.
Looks similar to the 95mm2 triplex I'm used to seeing. But a copper core rather than aluminium core. (More than likely due to costs) View attachment 28109which we use on our 11kV systems.
What isn't clear from the picture is that the lead sheath and outer servings have been stripped back and the red heathshrink applied over the cores. The triplex you can see in the trench underneath is presumably what is going to be jointed onto the cable.
Originally Posted by TJ Anderson [ElectriciansForums.net] Can anyone guess an work this out
You lot should have gone to specsavers. It has Raychem branded on it!! They were founded in 1957 so it is definitely after then.
Raychem produce heatshrink termination kits and joints for just about every type of generally used MV/HV cable past and present.
Originally Posted by Beavstro [ElectriciansForums.net] Can anyone guess an work this out
What were seeing in your photo is a cable end in preparation of being made off, while in the OP's photo's, it looks like nothing has been done to prepare the cable. In fact the more i look at those photo's i'd say that the original joint has been cut out, the Raychem heat shrink is a dead giveaway that these ends were once part of a terminated joint or even a termination into an enclosure...
Yes I'm sure you're right Tony, I just saw thick strands to begin with but realised that's not likely. I can't see how it would have been made for DC and then re-purposed for AC, unless it was 3-phase DC :) and then it would only have been for LV, as HVDC was the province of special systems like the Oxford 2kV system.
I’m not convinced that is 11KV, 3.3KV maybe, I think you would be pushing your luck at that.
Most 3 wire DC was 2½c so I think the DC idea has gone out the window.
Unless the OP comes back with some more information we’re wasting our time. Interesting non the less.
Reply to Can anyone guess an work this out in the UK Electrical Forum area at ElectriciansForums.net
